I have a mid 2010 iMac with a core i3 3.06 GHz CPU, and ATI Radion HD card with 256 MB a video room, and the 500 GB 7200 RPM HD. I am about to do an upgrade of the CPU, the GPU, and the Hd to SSD. It’s going to be a long tedious job, but doable. They are basically only two processor upgrade options that I am aware of and I chose to go with the Intel quad core i7 2.93 GHz That has the same socket type as the stock CPU. There is another core I five option, but I am upgrading this to the max. If you upgrade to the iOS 7, then you can use 32 GB of RAM instead of the 16 GB limit. Also, there are other graphics card options pulled from other imacs purchasable and eBay that you can swap for the stock built-in one. Changing from an HDD to an SSD is an enormous improvement in performance. And I’m not just talking about disc performance. But the entire system. I didn’t believe it until I tried it. As far as I know from everything I have read, there is no need to change the power supply when going with the CPU that I have bought. I’m actually about to commence the upgrade right now and really not looking forward to it. There are a ton of screws to remove in a lot of parts to take out. You literally have to disassemble the entire thing. As long as you follow the instructions and are very careful, it will be well worth it. You can take an 11 year old iMac and for $200, turn it into practically a brand new one as far as performance goes. The benefit is, you have peripheral ports that no longer exist so that hardware you might have that is fully functional you can still use, and you will not be forced to upgrade software because you can also run older versions of Mac OS X on other partitions. It’s also possible to remove the internal SuperDrive and replace it with another SATA SSD if you so choose. If you have the time, the patience, and the confidence, I say go for it
1条评论
Hi again everyone! Just thought someone might like to know that the Xeon E3-12xx v1 CPU’s work in 2011 iMacs ! I have a E3-1260L in my current 2011 21.5”. Only 45w
4cores 8threads 2.4-3.3ghz 8mb L3
由 Rodger Sinclair 完成的
