跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
memory RAM reuse recycle upgrade
I have several 1GB & 2GB RAM chips some are OEM 2gb from my imac and Macbook Pro that are still good can iFixit use them??? I cannot use them anymore and I do not want to throw them out! I upgraded the OEM are out of a 2009 27íMac i7 and 4 - 2GB are out of a 2011 27"i7 Imac
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The EMC 2429 i5 uses PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin).
Slower RAM will not work.
这个答案有帮助吗?
得分 1
1条评论:
Please do not change the original question, just add a comment to clarify.
The 2009 i7 Supports 1066 MHz PC3-8500 DDR3 SO-DIMMs (204-pin)
The 2011 i7 Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin) and will work for you.
完成的
添加一条评论
添加你的答案
Krisy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 216
