What would cause a liftgate to not unlock. All fuses are good.
Liftgate will not unlock.
Replace the ECC fuse 10 amp in the instrument panel fuse box just to be sure it's working, this powers the liftgate. Here's a teardown of the problem and possibly how to fix it:
Read more: http://www.justanswer.com/questions/21db...
这个答案有帮助吗?
Hers an additional fix for the problem. Ralph
I had the same issue and I replaced the ECC 10A fuse which fixed both my liftgate locking and rear air to start blowing again. However, the fuse blew again in less than a day.
这个答案有帮助吗?
Mine is doing the same. Did you ever fix yours?
For my 2006 GMC Yukon I cannot find the specific place where my ecc 10 A fuse is? Can anybody tell me?
Where is it located? There are three fuse boxes on these trucks.
If your liftgate closes, clasps, then releases without locking, after having to replace the rear liftgate glass, then likely the sensor in your liftgate actuator is failing. if your liftgate window glass breaks, tiny pieces fall directly into the actuator. Sometimes you can slam the door several times to dislodge them, but the grease in the actuator's gears will most likely hold onto the glass bits and continue to be an issue. You can try to flush the unit with cleaner and then re-lube it, but you still may be unable to get it all. The actuators are fairly cheap on Amazon and eBay and very easy to replace yourself. Took me about 15 minutes and most of that was finding the correct star-head bit to remove the 3 screws.
Dears ,
You can change the machine of lift gate by normal center lock, like this :
It's comes with small rule you'll fix it by any hall on the body it's and connect the two wire with the original harness.
Only need to make small hall on the plastic to make it lock or unlock the lift gate and remove the gear from the original machine.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 25
总计 76,383
1条评论
Can you give us more information? The liftgate is electronic?
由 Kyle Wiens 完成的
