跳转到主内容
The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 个问题 查看全部
Putting a 3rd hd in the zip caddy of a g4 quicksilver
I followed the g4 quicksilver teardown sequence( (step 11-12) and I want to add a 3rd hard drive. The drive fits in the zip tray alright but the screw holes on the drive don't line up. Do I need to alter this caddy to make it fit or can it just lay in there?
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
velcro works fine for this type of thing
这个答案有帮助吗?
得分 3
3条评论:
Good idea!
完成的
I agree. Ralph +
完成的
What is the master-slave relationship of the drives (2 per bus)?
完成的
添加一条评论
You should be able to just lay it there, it really isn't going anywhere. You could drill new holes if you wanted too, but it shouldn't be nessicary.
这个答案有帮助吗?
得分 0
添加一条评论
Thanx very much for your answers, I took my Dremel and 'oval'ed the hole out to fit the screw in. But after reassembly, then my old Pioneer 104 optical DVD drive went dead. Ah well, back to the workbench.
thanks and regards,
Crocdog
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Crocdog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,048
