跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
4s does not connect to any wifi at all
My 4s just been used for one year, never been dropped. One day, it just stopped to connect to any wifi. Under the setting wifi, it is completely greyed off. Apple tech said the chip to connect the wifi is broken. This phone cannot connect to any wifi now. I have tried switch off and on and still not help. Any expert has idea how to fix that? I am so disappointed with this Apple now!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
bad apple, I guess the very first step would be to disassemble the phone to see if there is any obvious damage to the WiFi circuit. Sorry about your bad experience. With a greyed out WiFi it is usually that the firmware does not find a Wifi IC
完成的
添加一条评论
3个答案
已选择的解决方案
I had the same issue last week on a 4s. Turn off the phone and use some 94%+ alcohol to clean the contacts and the black grounding clip that covers the wifi connector. I learned the hard way when these guides say, "on re-assembly clean part x", to do it and don't touch the clean area. If that doesn't work the cable or circuit is faulty as stated in by OldTurkey & Jack.
这个答案有帮助吗?
得分 2
添加一条评论
Check your bluetooth, can you use that? If your wifi/bluetooth is grayed out you can do the following; (Warning: If done incorrectly you can destroy your phone.)
Dissasemble your phone, take out the motherboard. Locate the wifi/bluetooth chip and remove the black tape covering it. The chip should look like this; (http://i1.ytimg.com/vi/N3Nn59ZJmyM/maxre...)
Use the smallest heating tool you have at your disposal to warm up the chip along the edges. Ensure you spread the warmth evenly to avoid any damage. Note, the chip needs to get hot. Avoid warming other parts of the phone! If you only have something like a large heat gun or a blow dryer I'd suggest covering the surrounding parts of the motherboard with some kind of heat protection, such as tinfoil.
Allow the motherboard to cool off.
Reassemble your phone.
I've fixed this problem 4-5times using this method. The first time I did was very crude, with a large heat gun. The second time I pulled out a smaller tool, used mainly for soldering allowing me to direct the heat to the wifi/bluetooh chip and that chip alone.
这个答案有帮助吗?
得分 1
添加一条评论
Try restoring. If that does not fix it, replace the wifi antenna. If that doesn't fix it, replace the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bad apple 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 915
