跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
New LCD screen goes white but it works fine if pressed.
Ok,
My neice threw her iphone 3G at&T so I had to replace the following parts; Full front LCD screen, REAR cover, Power, mute, volume, buttons and corresponding flex cables.
Now, when I try to set the front glass into place with the body, it refuses to seat level, one corner is either sitting low, or the other 3 corners are sitting high.
BUT. the main problem I have is this, after making sure all the LCD connectors are correctly connected, the LCD is white. BUT if I press down on the front screen above where the LCDconnector is connected to the mainboard the display pops on and as long as I keep pressure applied to that spot the phone works 100% fine, but, as soon as I let off, the screen goes white again. It is almost like the connector is not staying fully connected but when I open the phone and check the connection, it is nice and tight. Anyone got any advice on this issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Rear replacement housings are almost always a bad fit, the only ones I have ever managed to fit properly are the ones with the bezel already attached to it.
As for the LCD try to make sure no dirt or debris is in/around the connectors on both the board and the LCD flex cable. It may be worth cleaning them both with isopropyl too (make sure to use 99% or above and a clean cotton bud or piece of microfiber cloth).
If this doesn't work then the LCDs ribbon cable may be damaged and the whole part should be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
The reason why the corners don't sit right is because the rear housings that are available are aftermarket.
I actually stopped providing rear housing replacement in my repair shop because of this. I could never get them to sit properly.
It does sound like the LCD connector is not seated properly. Have you tried a hard reset after closing the phone up?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 926
