跳转到主内容
2006年十月在北美发布(然而2021才翻译。。15年的坑)
288 个问题 查看全部
Wii Freezes Upon Spinning Up Disks
My Nintendo Wii worked correctly until I left it in the car in the cold for a few days, and moved it between a few houses.
It now freezes at the Channel menu about 10 seconds in, when it begins to try to spin up a disk. It freezes before it shows a game if one is inside; it only shows the disk loading animation. The Wii then freezes completely, and must be restarted by holding down the power button. Before it freezes I am able to sync remotes, remove and put games in, and move the pointer on the screen.
I am assuming it's an issue with the disk drive, but I was hoping someone on here could give a second opinion. If there is any more information anyone may need, I'll try my best to give it.
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
dotmaners, you said "in the car in the cold". How cold are we talking about?
完成的
A little before Winter set in in Ohio - it was a while ago. I'm going to have to guess ~30 F.
完成的
添加一条评论
2个答案
已选择的解决方案
hmm sounds like it could be a lens problem, try this http://howtofixstuff.blogspot.ca/2013/08...
这个答案有帮助吗?
得分 0
添加一条评论
Actually it's not an issue with the drive. Although it's contributing to the problem.
Leaving your Wii in the sun will cause the motherboard inside to swell and bend from the heating up and cooling down process. You have created bad solder joint inside the Wii. When the Wii powers on, it takes minimal power consumption. Thus working fine at the dashboard. When you put in a disc you cause the Wii to draw more voltage / current and therefore process more electricity throughout the machine. the cold / bad solder joints are failing in the process of transferring electricity to components causing the freeze.
这个答案有帮助吗?
得分 0
1条评论:
The Wii was not heated up at any point that I can think of - could the cold (~30 F) alone cause this?
完成的
添加一条评论
添加你的答案
dotmaners 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,677
