跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
How do you repair or replace ethernet port?
I have a first generation PS3 and there is no internet connection upon connecting an ethernet straight from my router. I have tried all troubleshooting of it being a router/internet issue. I believe the ethernet connector itself is loose or broken. I need a guide on how to replace the port. I tried local shops and they don't know how to fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Very first question I would ask you, is if you have soldered on a logic board before? I had a difficult time with the USB port re-soldering. I found that the solder used by the manufacturer seemed to be difficult to melt. You will need a good soldering iron/station and some good skills to get this done.
完成的
If I have a guide I can do anything. I have soldered audio equipment before amps and subwoofer wiring etc.
完成的
添加一条评论
1个答案
You need to dismantle it to the logic board, then use a desoldering braid to remove the soldered connections of the ethernet jack, then put a new one in.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 3,614
