跳转到主内容
加入维修社区 - 创建账户
The Samsung Epic 4G is the first US released version of Samsung's Galaxy S II. Also known as the Samsung Galaxy S II Epic 4G Touch.
Battery would not charge, replaced it, new one wont charge?
Battery would not charge,replaced it,new one wont charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Are you using an AC charger? Checked the cables? Checked the connector?
完成的
添加一条评论
3个答案
最有帮助的答案
I'm betting its a problem with the charging connector on the phone. I've seen a lot of Samsung phones with the charge port go bad or come loose and not make contact. Unfortunately most of them are machine soldered to the motherboard making it extremely difficult to replace.
Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
I have this same problem. It is not the connector, as it shows it's charging (charge light turns on), and when it was plugged in all night, it "charged" to 0%, but the phone stayed on, showing me that it receives power through the cable. It's not the battery, as I checked the battery's health and even bought a new one, and saw the same problems.
It also occasionally charges, but usually not above 70%, and it doesn't consistently charge to the same level. It also doesn't actually charge each time it's plugged in, and there seems to be no pattern over 5 days of when it decides to charge other than that if it is charging, and is disconnected, when plugged back in it will not charge again.
It's a weird issue. Anybody seen this before? I'm guessing its a software/firmware problem, because it's actually getting power.
这个答案有帮助吗?
得分 0
添加一条评论
I chatted with some of the EEs in my office, and we decided that probably the charging circuit in the phone is shot. This means that I will need to charge it externally, so I'll be able to charge it. As far as I know, there is no way to fix this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
martin galindo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 1,405
