跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
LCD Backlight doesn't work
Hi
My screen in my iPhone 3GS brake I buy 2 screen (all front panel) from eBay.
I replace the screen but the backlight doesn't work in 2 screen.
In laboratory checked my coil 6R8 and say 6r8 coil work
But the backlight doesn't work what should I do?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Install a screen and do a hard reset. Holding the power and home button for about 10 seconds and the device will force restart. Sometimes this needs done when a new LCD is installed.
Hope this helps!
这个答案有帮助吗?
得分 1
2条评论:
Sorry but is doesn't work I tried restore and is not help. What should I do?
完成的
I want to add that the iPhone fell while I was playing basketball from about 2 meters. I didn't see any broken connectors I also tried spray cleaner but it still not work.
完成的
添加一条评论
Avior, the problem that you are running into can be multiple issues. If you replaced the LCD, and you know for sure that it is working, and if you know for sure that your coil is working, then the only other thing hardware wise would be the backlight IC 109B. The IC is readily available and you can check on here to see if you are wanting to change that. Before you go that route, I would double check all your connectors, your cables etc. and make sure that you have LCD's that do work. It really depends where you purchased yours from, there is always the possibility that they are not working. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
1条评论:
Avior, just now
完成的
添加一条评论
添加你的答案
Avior 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 922
