跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Random freezing and display fault
HI,
Recently I'm facing issue with my white MacBook (Early 2008) which is randomly freezing and a message shows that i have to turn off the machine. Sometimes during this freeze the display shows some sticky line or numbers or characters flickering.
Best Regards
Aryan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Often when I see a system freeze up it's caked up with dust and likely needs to have the thermo paste re-applied. I would start with cleaning if the problem is still persists you may have to reformat the HD and re-install your OS & files (your HD maybe having problems).
Are you up to taking your system apart? Do you have the needed tools, ESD mat & wrist strap?
If you do follow this guide Upper case removal. Make sure to fully scrub down the logic board, heat sink fin from the back and fan with a soft brush. Using can'ed air blow out the junk. Follow proper ESD practices!
If the system is not that dirty you should consider pulling the heat sink off so you can apply fresh thermo paste onto the CPU & GPU to get better heat transfer as the old paste is most likely not doing a very good job any more (causing the fan to run hard). Follow this guide to Step 26 (you don't need to go all the way here) Logic board removal
MacBook Core 2 Duo Upper Case图片
指南
MacBook Core 2 Duo Upper Case Replacement
难度:
中等
45 minutes - 2 hours
MacBook Core 2 Duo Logic Board图片
指南
MacBook Core 2 Duo Logic Board Replacement
难度:
困难
2 - 3 hours
这个答案有帮助吗?
得分 2
3条评论:
hi,
but this is not related to over heating or HD, its happening usually only when im moving it....
完成的
Your system was not designed to be moved about running, lid open (excluding sleep mode).
完成的
I would still do a good cleaning first as your system likely needs it do to it's age.
完成的
添加一条评论
添加你的答案
aryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 142
