跳转到主内容
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
My pause/play button doesn't work, can it be fixed?
I usually listen to my ipod on one of the docking stations while I am in the shower... but one day when I took it off and plugged in my headphones I could not turn off my ipod and I could not use pause/ play button at all.
I have tried resetting it and it didn't do anything. I have also tried sticking it in rice thinking maybe it got in the play button... I am not quite sure if it did, but it is possible since I play it while I am showering.
What can I do to fix it?
Do I have to send it back and see if someone can fix it or replace it?
I don't know that my ipod is under warranty anymore... I really don't want to have to buy a new one because I cannot afford that. Please help me fix my pause/ play button. That is the only thing that doesn't work. All other buttons work and if I put it in the docking station, the docking station can pause it...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
hello there looks like I've got the same problem ...So I've just resetted my ipod and i was working fine ...I attached a link on hot to reset ur iPod
https://www.youtube.com/watch?v=EY7P4ixY...
完成的
添加一条评论
4个答案
已选择的解决方案
Katelynn, sounds like you are having some click wheel issues. You can replace it by yourself. It's a bit cumbersome, but not really that difficult. Follow this guide to work on it. The part is available right here as well as many other places. It will depend on your location. Hope this helps, good luck.
Replace a broken or damaged click wheel for your iPod Classic with this part. This product does not include the button and can be identified by 821-0545-A printed on cable.图片
产品
iPod Classic Click Wheel
$12.99
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Okay this worked for me and for so many other people. But all you need is a cotton ball/pad and rubbing alcohol. I know it sounds crazy but trust me I just got done doing it and I just had to share it with people. Here are the steps:
1. Get a cotton pad and rubbing alcohol that is at least 70% isopropyl or higher. (Note: the rubbing alcohol cannot have too much water in it or it will ruin your device, so make sure it is 70% or higher).
2. Put a little bit of the rubbing alcohol on the cotton pad. [do not soak the cotton]
3. Make sure the lock switch is locked (idk if this is important, but that's what I did)
4. Hold down the play/pause button and gently dab and squeeze a little of the rubbing alcohol in the cracks of the play/pause button section.
5. Rotate your fingers along the scroll wheel to move the alcohol around.
6. Try the button! (Note: if it does not work, try again. I had to try a few times because I don't think the crack in between the buttons was big enough to let the rubbing alcohol through)
There is also a video of it on YouTube called "How to fix a broken IPod click wheel quick and easy" by a channel called Do It Yourself
Good Luck!! :)
这个答案有帮助吗?
得分 4
6条评论:
I was completely prepared to order a new click wheel for my I Pod Classic. The "menu" button was the only button that worked on a regular basis. Then I read your suggestion to use the rubbing alcohol. Presto! all buttons working properly! Thanks for the post!
完成的
for 5 years i decomissioned my ipod because of this issue. today i tried your solution exactly one time, jesus f christo it worked... i am stunned (mind you i'm a professional RnD engineer too, i feel quite dumb lol)
完成的
I just received a custom-remade iPod Classic with the same issue. I squeezed a ball of 91% isopropyl, wiped it around, and so help me, God, it was an instant fix!
完成的
I just found this after googling my issue and made an account just to reply and let you know that this instantly worked! Thank you so much
完成的
I created an account just to say this worked! I have recently been working on an iPod Classic and have replaced the click wheel, hard drive, battery, case, and headphone jack. After I did all that the next/right button still didn't work, luckily this did fix the problem! Try this before considering buying a new motherboard, or working on your current motherboard.
Also here is the link to the video mentioned in the main post/solution.
https://www.youtube.com/watch?v=-KNTqW6r...
完成的
显示更多的1条评论
添加一条评论
Why do you think it's a click wheel issue? The button for play/pause appears to be soldered to the logic board. I found my 80GB Classic this week and my play/pause button is working VERY intermittently, looking for any thoughts...
这个答案有帮助吗?
得分 0
1条评论:
For what it's worth, I have a 30gb fifth-gen iPod in which the little rubber thingy under the wheel got dislodged, causing no contact to happen. The fix was simply to put it back in the right spot under the wheel.
完成的
添加一条评论
Howdy!
To get right to the point: I had this exact problem on my 7th generation thin ipod classic. I replaced the click wheel. I am happy with the new click wheel but it did NOT fix the same play button issue that I was having. I even cleaned up the logic board and it did not help. So I think there may be a problem with the logic board. I could replace that.....
I did replace my headphone jack which was not working and BOY does it sound good now. I just use headphones that can electronically play/pause the ipod for a short-term fix.
NOTE: I don't know if it is really a logic board issue, but neither click wheel works so I couldn't imagine it is anything else!
Me
这个答案有帮助吗?
得分 0
1条评论:
I got an anti-bacterial wipe from tesco and went inbetween the creases of my scroll wheel and its good as new!
完成的
添加一条评论
添加你的答案
Katelynn 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 66
总计 20,991
