跳转到主内容
加入维修社区 - 创建账户
The Kenmore Direct Drive is a washing machine by Kenmore.
My washer won't drain out, but it spins & agitates
Why won't my GE top load washer drain? It spins and agitates.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
这个答案有帮助吗?
得分 3
1条评论:
i have removed my drain pump impeller and cleaned it. There is no obstruction but it does not spin easily.
完成的
添加一条评论
there could be the lid switch as the problem
这个答案有帮助吗?
得分 0
添加一条评论
Had this problem twice.pull pump inlet hose and check for objects jamming impellers.once mine had a bottle rocket stick in it and another time a wire from a bra.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
socorro herrera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 5,172
