跳转到主内容
Why not able to format/partition SSD?
i bought an Sandisk SSD (UltraPlus-128GB) and replaced my faulty Hard Disk in my MAC-book Pro.
After install, The device is detected in "Disk Utility", but i am unable to format / Partition the disk.
Error :
Partition failed with the error:
"POSIX reports:The operation couldn't be completed. Cannot allocate memory."
Regards,
Mani
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
See if there are jumpers on the drive as it may need to be slowed down to be seen.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for help...No jumper in this drive... Below is the FYR..
http://www.sandisk.sg/products/ssd/sata/...
any other suggestion ?
完成的
Yes, it's getting hard finding SSD's that work with SATA I or SATA II interfaces. Many are only able to work with SATA III now (newest models)
完成的
The SanDisk Ultra Plus Solid State Drive is compatible with SATA Revision 3.0 (6Gb/s) interfaces and is backwards compatible with SATA Revision 2.0 (3Gb/s) and SATA Revision 1.0 (1.5GB/s) interfaces. I
Try replacing the hard drive cable. These cables have become my most common repair. I now keep two each of the 13" & 15" cables in stock. http://www.ifixit.com/MacBook-Parts/MacB...
完成的
添加一条评论
添加你的答案
manivannan sozhan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,161
