跳转到主内容
Trackpad doesn't work correctly
I bought an used PB for my son.
The trackpad pushbutton doesn't work that good. It doesn't "click" like I use to know it from mine. Often I have to press
the pushbutton more than one time. It is not aout of order, but it could be much better.
What can I do?
Thank you!
regards from Germany
George
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Hi. The only repair for the trackpad I know of is to replace the top case as it is built in. I'm including the teardown and part number for this repair. If it were me however I would just buy a USB mouse and use that. ( A whole lot less money) Ralph
PowerBook G4 Aluminum 15" 1.67 GHz Upper Case Replacement
[关联产品丢失或禁用: IF154-112]
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Sounds like you may have gotten something in the side or under the pad. Take a thin stiff piece of plastic and run it around the pad to see if you can dislodge anything.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 898
