跳转到主内容
Using a hard disk cable meant for a different model
Hi all,
Ive recently had my hard disk cable die on me and im running my macbook of a usb flash disk now. Im using a mid-2010 13" Macbook Pro that uses an Apple Part #: 922-9062 hard disk cable.
The problem I have now is that by mistake, I've ordered Apple Part #: 922-9771 instead that is meant for the 2011 model. My question is, would the part still be compatible or does the problem lie possibly with a different connector that connects it to the logic board?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
These parts are interchangeable: 922-9062, 922-9771, 923-0104
The cable you ordered will work with the following:
MacBook Pro 13.3" 2.26GHz Core 2 Duo (A1278) - Mid 2009 MB990LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.3GHz Core i5 (A1278) - Early 2011 MC700LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.4GHz Core 2 Duo (A1278) - Mid 2010 MC374LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.4GHz Core i5 (A1278) - Late 2011 MD313LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.53GHz Core 2 Duo (A1278) - Mid 2009 MB991LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.5GHz Core i5 (A1278) - Mid 2012 MD101LL/A SKU173362
GS173362
MacBook Pro 13.3" 2.66GHz Core 2 Duo (A1278) - Mid 2010 MC375LL/A GS17336
SKU17336
MacBook Pro 13.3" 2.7GHz Core i7 (A1278) - Early 2011 MC724LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.8GHz Core i7 (A1278) - Late 2011 MD314LL/A SKU173361
GS173361
MacBook Pro 13.3" 2.9GHz Core i7 (A1278) - Mid 2012 MD102LL/A SKU173362
GS173362
这个答案有帮助吗?
得分 2
添加一条评论
Mayer,
922-9062's are not interchangeable with 922-9771. The 922-9771 is too short to connect the Logic board to the HDD in a 2009 or 2010 13 inch MBP. I've seen a 2011 13 inch MBP with a 922-9062. It may work, but who knows for how long. Since the cable is too long it wouldn't sit right causing folds.
这个答案有帮助吗?
得分 0
添加一条评论
If you're desperate, you can make the short one reach if you don't use the two 3mm screws that hold the middle of the cable down. I wouldn't advise it. I did it but it failed eventually after a couple of years. 922-9771 (821-1226-A) is too short. Use 922-9062 (821-0814-A) because it is longer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lam Hew Tot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 981
