Released in 2007, identified by model number WD-57734.
14 个问题 查看全部
Projection shows black & white flakes?
Projection image shows flakes when viewing. Flakes increase every on/off cycle. Almost unviewable. Any suggestions?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Thank you, very helpful. Once i gained acces from side panel only thig left was projection. A relief to know
You are welcome and hopefully you will get it fixed.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
PWILLIAMS, sounds like your DLP chip is failing. It literally has thousands of tiny mirrors on it and each "flake " you see is a mirror failing. This is a known problem for this model and Mitsubishi had at one time a program, to cover 1/2 half of the repair cost. You may want to contact them on here. If not, then use this guide to replace this chip. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
PWILLIAMS 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 443
