跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Keyboard and Trackpad Not Recognized
My old machine had been quite slow, so I opened it up to give it a cleaning. I removed a huge amount of dirt, put it back together, and things were flying for a couple of days. Then the keyboard and trackpad stopped responding. (The power button still works)
I then opened it back up to make sure that the connection to the logic board was clean and without any bent pins. Things looked good. So, without fully assembling the machine, I plugged it in and started it up. Still great. But then I put it all back together, and again the keyboard/trackpad isn't recognized. Is there something that I may be over-tightening? What else could be wrong? Please help.
Josh
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Remove the macbook battery and check if the battery has taken expension. Sometimes the battery is bulging and then compress the trackpad and the keyboard connection.
Remove the top case, check the trackpad/keyboard connections, reattach the top case to the macbook and try the machine without the battery installed. Let us know......
这个答案有帮助吗?
得分 1
2条评论:
The battery, while quite old, seems to be alright - no noticeable swelling or the like. Starting up from AC-Power alone doesn't make a difference, but like I posted, when I run the machine without the top-case secured, then it works fine. It seems to be a problem that occurs when I close everything down. It doesn't make much sense to me.
完成的
well, make sure you install the right screws at the right locations and you dont need to apply much force on the case screws.
完成的
添加一条评论
添加你的答案
Josh Frankel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 578
