跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
What else can I put in place of optical drive?
Now the title reads: "MacBook Core 2 Duo Optical Drive Replacement".
I just wanted to check whether another optical drive must be replaced, or whether we can replace with a standard 2.5" HDD (like the standard one in macbook) for extra storage as optical drives are practically becoming obsolete.
If so, anything else we should like out for when installing the secondary HDD?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
iFixit sells an Optical Drive Enclosure for your MacBook Core 2 Duo. This lets you add in a second hard drive in place of the optical drive. Most of us here have that and we love it!
这个答案有帮助吗?
得分 3
添加一条评论
Yes you can replace the optical drive by a second hard drive. You need to install an internal enclosure that contains the hard drive and the connection to the logic board. Here's a listing from Macsales.
http://eshop.macsales.com/Search/Search....
这个答案有帮助吗?
得分 2
1条评论:
or a SSD unit
完成的
添加一条评论
This does not include mounting hardware & cable. Just received my enclosure. Perfect fit, but useless, as there's no way to hook it up. I guess they assume I'm removing an existing optical drive, and I'd have the mounting kit & cable. That's been removed from this machine a long time ago. Apparently ifixit doesn't supply those.
这个答案有帮助吗?
得分 0
1条评论:
Did you take your optical drive out and not save the parts? The cable is available as a spare and you might find the screws from someone as well.
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 425
