跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
Dark Screen not fixed - Changed Inverter and LCD Panel. What Next?
Hello everyone. I am trying to fix up a 2.0 Ghz 2006 MacBook for my mum to use. About one year ago the screen went dark, you can still see its working under a flashlight but the MBs backlight is not working.
I bought an MBP so have not tried to fix it until now....I have changed the inverter and the screen (at great expense) and its still not working!! what shall i do next??
please help
g
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
After changing the display can you see it is working when lit with a flashlight ?
Yes : the backlight still isn't working.
What do you know about the exchanged parts ? Brand new or used ? Even new parts can not always be trusted to be all right. So it still could be the inverter, or the lamps in the display panel.
When these parts are brand new and tested, check the inverter supply (mostly 12VDC) voltage. Maybe there is a fuse on the power supply which has blown. Also check the low voltage wiring to the inverter. There can be a short circuit in the high voltage wires to the backlight lamps, causing the fuse on the new inverter to blow instantly. SMD fuses can be recognized by the desription on the PCB (F1 e.g.), and can easily be tested with a multimeter, and replaced by a glass fuse by soldering wores to it.
Then there is the baklight control voltage (mostly a PWM signal) coming from the motherboard to the inverter (sometimes passes the power supply PCB). It controls the brightness of the backlight and could be missing or too low. Then mostly there is a Backlight_ON/Inverter_ON signal which could be the cause.
The backlight lamps can not be tested with a multimeter (infinite resistance), and they normally break only because of over-aging (or by heavy mechanical shock).
When you can't see anything with a flashlight on the new TFT panel, it could be broken (even though it is new). Try testing the old TFT to see if that one is still displaying something (maybe by connecting the new TFT you broke the video card).
Please let me know about your own diagnosis and remedy.
这个答案有帮助吗?
得分 3
1条评论:
very good explanation = +
完成的
添加一条评论
The last piece to replace in the display would be the inverter cable. This can also cause no backlight.
这个答案有帮助吗?
得分 2
1条评论:
hi guys thank you both very much for your advice...
I m slightly embarrassed to admit that I have solved the problem simply by disconnecting the inverter cable from the logic board, blowing into it and then replacing it...! it was an extremely technical process :)
In my defence I had tried this once already without success..
Anyway it works now, but I am faced with the task of trying to return an expensive LCD panel to someone who doesn't really want it back..
Thanks again for your advice,
gt
完成的
添加一条评论
添加你的答案
Graham Taylor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,569
