跳转到主内容
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
Pins or SIM card contacts are broken on blackberry Z10
SIM card is not recognized and it looks that 1 or 2 pins on the SIM card tray are damaged or broken . Can this be repaired or replaced or all motherboard has to be changed . And where an you buy spare parts for Z10
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
This should be a relative new phone. If you are covered under warranty, I would try that first.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi Nabil,
Can you figure out if the pins are just damaged or if they are actually broken?
In case the pins are damaged, there might be a chance to simply but carefully bend them back into their original position, for example with a tiny item or tool (e.g. toothpick or mini screw driver). Make sure that you remove the battery first before you try any repair on the sim card reader.
Use this teardown of the Z10 here on iFixit which will help you how to open your phone.
Steffen
这个答案有帮助吗?
得分 3
添加一条评论
Here is some information on the repair
http://www.mobiledeviceworkshop.co.uk/bl...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nabil Hamdan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 18,894
