跳转到主内容
Released in Late 1993, the Macintosh Quadra 610 and Macintosh Centris 610 are two closely related personal computers that are a part of Apple Computer's Quadra and Centris series of Macintosh computers, respectively.
4 个问题 查看全部
How do I fix the resolution on my screen?
I just got my macintosh and booted it up and the screen said the resolution was out of range, control panel doesn't open.
also I want to remove the previous owners files, should I reinstall the system? (i have reinstall disks from my powerbook 100 that may work)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
First check to see if the video RAM slots are filled. Two internal Video RAM slots can take either two 256 kB 80 ns 68-pin VRAM SIMMs, or two 512 kB SIMMs. Installing one 512 kB and one 256 kB VRAM SIMM garbles the display. See if you can find, then press the reset button on the logic board. Did you replace the 3.6 volt PRAM battery? Next try zapping the PRAM (command - option and P and R keys held down on start up.)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ted Mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 321
