跳转到主内容
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 个问题 查看全部
My phone has been damaged by alcohol?
ok so i decided to test out a rumor about bathing your smartphone in isopropyl alcohol beings my phone had a bunch of grit/dirt in it. it work just fine before the bath. now it turns on and it functions with 2 problem tho.1) it has dark blotches all over the display.2) it has trouble reading the sim card(as in it still reads the sim card just poorly) and ideas would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Replace the logic board and display assembly. And never put your phone in a liquid, as it will seriously damage it.
这个答案有帮助吗?
得分 2
2条评论:
" never put your phone in a liquid, as it will seriously damage it." not quite correct. It is perfectly okay to submerge and phone or electronic component in something like isopropyl alcohol or sterile water. The only thing with isopropyl alcohol is to use a concentration high enough i.e. 90%+ to clean the device. It will displace water and evaporate quickly. Submersion in any of these liquids does not contribute to failure. It also does not destroy plastics etc. It is really not a rumor to use this to clean your phone.
完成的
ty jack
完成的
添加一条评论
添加你的答案
Scott Darr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,897
