跳转到主内容
MacBook Pro带有15寸屏幕的型号
8255 个问题 查看全部
RAM Upgrade - CPU Panic
Hello,
I own a MacBook Pro 15" Mid 2010. Currently I have 4GB of RAM and I wanted to upgrade them to 8GB. So, I bought these:
2 x Corsair 4GB DDR3 SDRAM Memory Module - CM3X4GSD1066
Corsair - Memory - 4 GB - SO DIMM 204-pin - DDR3 - 1066 MHz / PC3-8500 - CL7 - unbuffered - non-ECC
I easily installed them on my MacBook Pro but on the boot I receive errors like "CPU Panic" and other "Non-sense" error codes :)
Are these products not compatible with my MacBook Pro (although the specifications should work) or am I doing something wrong here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Hi Andrei, in terms of compatibility everything seems to be fine. Besides the memory upgrade, did you also upgrade your software? What happens if you insert the old memory modules? Do you then get the same errors/errors at all?
完成的
I am using OS X Mountain Lion. Now I am using my old memory modules and everything is working fine.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi Andrei,
Thank you for your feedback and update. I am sorry to hear that you had to "downgrade" your memory again.
I did some further research on this issue and figured out that the new corsair memory might (yet) ultimately cause the issue. See discussion 1 and discussion 2 on that.
I recommend that you get you some crucial memory. Go to the crucial website and scan your system in order to know what your system can take. As far as I can see, crucial memory is one of the best memories and does not create issues when it is about a memory upgrade.
I hope that you can give back your corsair memory modules...
Steffen
这个答案有帮助吗?
得分 1
添加一条评论
The problem seems to be related to nvidia's DRAM Controller. Probably you have to change SPD timing to 8-8-8-20 to meet DDR3-1066G specification. To change timings and write them to SPD use Thaiphoon Burner utility.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrei R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,094
