跳转到主内容
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
37 个问题 查看全部
Is it possible to replace the screen?
My chromebook screen is broken, it's got a massive black spot (1" across) and the screen is covered in random lines. I can only assume it took a hit but the case is undamaged. Any idea if it would be possible to replace, and if so where I could get the replacement screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 34
8条评论
Just out of curiosity, have you checked to see if you get this done under warranty? It is a pretty new device and I am sure it should still be covered.
完成的
how would you know if it was under warranty
完成的
I have the exact same problem mines about 2 years old and i use it pretty frequently
完成的
I just did this. Took all of five minutes. Bought screen from Amazon for $37. Really easy.
完成的
Check out screensurgeons.com for videos that will step you through the process. Quick and easy.
完成的
显示更多的3条评论
添加一条评论
5个答案
已选择的解决方案
Hello,
I was searching to replace the panel with a better one, and I found a video on youtube:
http://www.youtube.com/watch?v=_mgyuVTTh...
It is made by some guys who also sell the panel.
The panel datasheet is available on the Internet, though (just google it).
Jacobo
这个答案有帮助吗?
得分 6
添加一条评论
These screens can easily be found on eBay and Amazon.
For the US Chromebook for example, I searched for the model number and LCD replacement like this "XE303C12 LCD replacement" on the Google. Found a new screen with Prime shipping on Amazon for about $45.00 US.
Install was as described in the other answer, but I did run into a small amount of adhesive tape on the bottom of my already broken screen and the bezel. I was not to worried about it but it took a little more force than I expected to get the bezel removed.
这个答案有帮助吗?
得分 5
2条评论:
yessss i saw that and thats what i am going to do . Good in fo thanks
完成的
Thanks i now get another but it costs $60 yep --> $60 <--
完成的
添加一条评论
I work for a school and we have about 120 of these. The kids break the screens all the time so I've replaced about 20 of them. Its super easy, follow the youtube video above and order the screens from Amazon. The only things to be careful for: (1) cheap replacement screens can are just that; cheap. I have learned the hard way to only buy from VIV tech as I have been burned with crappy screen that don't fit right from other companies. (2) take a look at your old screen before buying. Some Samsung replacement screens have side mounting brackets and others have top mounting brackets. Make sure you order the one that fits yours.
这个答案有帮助吗?
得分 2
1条评论:
What is VIV tech - the only references I found had nothing to do with dealing in parts for Chromebooks and laptops Thanks
完成的
添加一条评论
No its not under warranty unless you paid extra. Mine is 45 days old and was sent to a HP Centers . 260 ..00s . It s a design flaw and should of been under warranty as i had lines going across first then by inspection it around the edges it cracked .
这个答案有帮助吗?
得分 1
3条评论:
They are sending it back to me
完成的
so i can fix it for less .
完成的
i have broke my screen how much would it be to repair the screen for a chromebook samsung
完成的
添加一条评论
I found the Samsung warranty to be worthless. They falsely claimed water damage, but I bought it in a dry, sealed box, and it was never near water. Fortunately, Wal-Mart's extended warranty fixed it, even though the Samsung warranty should have. My LAST Samsung product!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
George Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 62,559
