Touch screen comes off without the screen block.
Hello I've just tried to change my battery but I've pumped into a problem the touch screen comes off but not the screen, How can I work round the problem?
Are you able to show a picture of what your screen looks like? The display assembly is 2 parts, but they should come with screws holding them together.
这个答案有帮助吗?
I don't have the phone with me, wanted to change a friends battery, basically the digitizer seems to have come unstuck from the metallic holding part with the screws in, so it comes off without the screen pannel.
I'm upping the post.
I added a photo.
Looks like the adhesive got old or something and the front panel is just coming off. We sell adhesive strips for that part to fix that. To get the rest of it out, you could try using some needle noes pliers or something.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 342
I'm upping the topic as the awnser is not correct.
由 Ben Hard 完成的
https://mega.co.nz/#!9pJmlaCT!N24kBx_axj...
由 Ben Hard 完成的
i believe you removed your screen incorrectly.
由 _Z_ 完成的
I followed step one, but the only thing to come off was the touch screen but not the screen with it... I'm more or less used to taking electronics apart and taking things easy, if I've got it right the touch screen is stuck to the screen if I've got it right, and it has come unstuck is there any way around this problem.
regards.
由 Ben Hard 完成的
Ben HArd, "To the left of the Home Button under the glass there is a small square port through the plastic midframe. Insert a small hook into this port and carefully pull the midframe up. Do this very controlled you do not want to suddenly open the iPhone and tear (break) the cables and connectors at the opposite (top) end of iPhone. Before opening and during repair of iPhone 3GS make sure it is OFF." from here. Follow the answers provided by either Brad or Pollytintop. Both should work for you.
由 oldturkey03 完成的
