Can see it, but it is very dark
I can see it, but it is very dark. Is it repairable?
Hi Cindy, Here is a link to the Dell service manual for your computer. Hope this helps you.
这个答案有帮助吗?
Usually a dark screen is not fixable because its the issue with LCD back-light which is pretty internal thing. You can get it checked from a hardware shop to make sure the if the LCD is defiantly gone if this is the case the you can order a new screen online to fix it by yourself.
这个答案有帮助吗?
both the answers above are acurate. but here is mine. yes it is from the backlight, i can tell you with 99% sure. Now you just have to check in the service manual if the backlight is repaireble. hope it helped ;)
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 180
1条评论
Sorry it's a Dell inspiron 1520
由 Cindy 完成的
