跳转到主内容
The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
16 个问题 查看全部
问题已关闭
Can see it, but it is very dark
I can see it, but it is very dark. Is it repairable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Sorry it's a Dell inspiron 1520
完成的
添加一条评论
3个答案
已选择的解决方案
Hi Cindy, Here is a link to the Dell service manual for your computer. Hope this helps you.
ftp://ftp.dell.com/Manuals/all-products/...
这个答案有帮助吗?
得分 2
添加一条评论
Usually a dark screen is not fixable because its the issue with LCD back-light which is pretty internal thing. You can get it checked from a hardware shop to make sure the if the LCD is defiantly gone if this is the case the you can order a new screen online to fix it by yourself.
这个答案有帮助吗?
得分 0
添加一条评论
both the answers above are acurate. but here is mine. yes it is from the backlight, i can tell you with 99% sure. Now you just have to check in the service manual if the backlight is repaireble. hope it helped ;)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 180
