跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Is possible to swap my logic board with a newer one?
Hello everybody,
My logic board (Apple Part #: 661-4834, 661-5098, 2.4ghz, as i discovered thanks to ifixit) is suddenly dead.
So i decided to buy a new one but i want to know if is possible to use a newer one, like the 661-4836 2.8ghz or even the 661-5213 (or whatever is possible!).
As far as i can image the ports and the sd card slot are a problem (except for the 661-4836 because is the same), but there are other issue?
thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
john madden???
完成的
john madden? what?
完成的
添加一条评论
1个答案
已选择的解决方案
If you stay within the same Model number you should be fine. Please give us the last three figures of your serial number or the Axxx number of your machine and we can get you to the correct part. Also why do you think your logic board is bad?
这个答案有帮助吗?
得分 1
5条评论:
The logic board is bad because the computer didn't start at all. Even with the magsafe connect I can't check the battery level. Plus an apple repair service told me that the logic board is dead.
My serial is: w88492ld1g0.
I think that i can change my logic board just with the 661-4836!
完成的
Apple MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) Specs
Identifiers: Late 2008 - MB470LL/A - MacBookPro5,1 - A1286 - 2255
完成的
Looks to me like the 661-4836 will work for you.
完成的
thank you!!!
完成的
Did the 661-4836 work? I have a bad logic board as well and its the 2.4 Ghz model, I was looking to upgrade it to the 2.8 with the logic board swap.
完成的
添加一条评论
添加你的答案
damocle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 644
