跳转到主内容
Model A1138 / 1440x960 screen resolution
85 个问题 查看全部
问题已关闭
Is there manual eject for the optical drive?
My friend has a dead PB and my disk is stuck inside.
I saw the take apart manual for a jammed disk,
but would rather not have to take it apart
just to find there WAS a manual eject .
I tried poking a paper clip here and there with no success.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here's the answer from Apple. Good luck Ralph
http://support.apple.com/kb/HT3064
这个答案有帮助吗?
得分 2
5条评论:
Push the paperclip straight into the hole, sometimes it takes some pressure to do this. +
完成的
this isn't one of the PBs with an eject hole.
None of the other methods will work because the machine won't boot up, it's dead.
I guess it's time to take the machine apart ......
the owner will want the hd out of it anyway.
完成的
Just inside the slot of the CD ROM drive on the right side "If memory serves" there is a little pad that you can push with the paperclip and it will activate the same thing that the ones with the wholes do.
完成的
Look at the picture in the link to locate the hole.
完成的
Mayer,
my machine has no case external hole for this.
that pic in the link is not what this machine has.
mactech,
I pushed and prodded but still didn't find it inside the slot.
machine specs:
(taking out the battery to see id plate)
PBG4 15.2" / 1.67GHz / 1 GB (2x 512MB) / 100GB
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,108
