跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Removing old solder when replacing speaker
I broke the blue and red wires when replacing the screen, The red one broke off the board and the blue one didn't. The wires are still sticking out enough on the speaker to use them. My question is do I need to desolder the solder from the board it connects to? Someone mentioned in another post that you can solder these wires to the top of the board instead of the bottom where it previously was. There are two gold contacts on the top of the board directly on the opposite side of where it previously was soldered to. I know the solder is conductive but is it okay if i solder the wires on top of the old solder?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Just tin the two wires and solder them back. If there is too much solder just use a braid and a bit of flux to remove it.
这个答案有帮助吗?
得分 2
1条评论:
How do you tin and why?
完成的
添加一条评论
It should be ok but you shouldn't need to put more solder on the board, just heat the old solder up and stick the wires in wile its still melted.
Hope this helps,
John H. Laney
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christa Bahr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 440
