跳转到主内容
加入维修社区 - 创建账户
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Adding Ram with different capacities
The last three figures of my serial number is 9VV. I bought the base model of Mac Mini with 2x2GB ram. I plan to upgrade and replace one of the 2GB with a 8GB ram. I read in one of the support answers that "RAM should be installed in pairs or the machine will suffer true performance set backs." Does this mean they should be of the same capacity as well? Will it affect the performance if I use a 8GB ram in one slot and a 2GB ram in the other?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
9VV didn't bring a machine up. If you have the 2012 model it uses RAM Type: PC3-12800 DDR3 Min. RAM Speed: 1600 MHz
Traditionally you gain what called interleaving with two identical chips giving about a 10% gain. Put the 8 GB chip in the A slot. Unless you are doing really intensive tasks such as PhotoShop rendering, your machine will never go past the first chip. Use a program like Hardware Monitor to see just how much of a load you are putting on your machine and then determine if the RAM you have is sufficient or maybe just a 4 GB chip would suffice.
http://www.bresink.com/osx/HardwareMonit...
这个答案有帮助吗?
得分 3
3条评论:
Thanks. I have been using the Eclipse IDE and flash player which causes the overall ram usage, including other applications , to over 4gb. I will try the hardware monitor and estimate how much I would need. But I gather from your answer that adding a 8gb and 2 gb ram shouldn't be a problem and I will only lose out on the 10% gain.
完成的
Which is slot A? The one closest to the board, or the one higher up?
完成的
The one you install into first (next to the board).
完成的
添加一条评论
添加你的答案
Sabman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,264
