跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
What do I use to "reglue" my wifi antenna?
A while back, I broke my IPod 4g screen, so recently I bought a new screen and replaced it. Worked great. However, in the process, I unattached and unplugged my Wifi antenna...It was held down with some sort of..adhesive substance. I plugged the antenna back in but now my Wifi goes in and out. If I hold it down with tweezers, my internet connection is fine, but once I let go, I slowly start to loose connection. I figure that I need some sort of glue to keep it held down, but I can't find exactly what I should use... Anyone know? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I would use some very very thin electrical tape, or you could find an equivalent to it. Basically the reason your wifi goes in and out is that the iPod uses the outer metal case to strengthen the antenna, hence when you press it against the case it works fine. All you need to do is find something that is NOT conductive, and is small and adhesive enough to keep it secured.
这个答案有帮助吗?
得分 1
3条评论:
Would liquid electrical tape work? I was looking at this: http://www.amazon.com/Star-Brite-1-Ounce...
完成的
Keila Black, that stuff might just work. It does fit all the criteria needed, just try not to make a mess with it :-)
完成的
lol. I imagine myself making more of a mess with physical tape..like accidentally ripping the WiFi antenna cause I taped it down wrong or something. XD but anyways, thanks for the help!
完成的
添加一条评论
Use Double Sided Tape it will work just fine. Put it between the antenna and the white plastic, not between the antenna and the front panel.
Use the transparent tape.
Do not use the black thick tape, or you will be not able to close the front panel.
这个答案有帮助吗?
得分 1
添加一条评论
Don't bother gluing it or taping it. The way the screen fits there is almost zero "wiggle" room for extra adhesives or tapes. You are risking having the screen sit unevenly and getting possible white pressure points on the screen and worst case scenario you could damage the LCD. Just sit it in the right place and install the screen. I have never had any issues doing it this way, just make sure the antenna is completely connected. You don't want to have to re-open it to fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keila Black 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 769
