跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
98 Trouble Catching Gears when accellerating and Sometimes Stalling
When starting to accelerate my engine seems to rev out before it catches a gear. Also, Sometimes when stopping and then trying to accelerate again, the car stalls. Whats wrong with it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Automatic or manual transmission?
完成的
It is an automatic.
完成的
This could be as simple as a bad sensor to as complicated as a burned clutch inside your transmission. Have your car hooked up to an OBD analyzer and see what codes, if any it throws.
完成的
If you can get to an OBD analyzer it will make life easy, if you smell something funny when your car stalls out... most likely a burnt out clutch.
完成的
添加一条评论
1个答案
已选择的解决方案
The automatic transmissions in Honda / Acura are known to be the weakest point on the car. They generally have problems and it sounds to me like you need to check the tranny fluid, and/or get it replaced.
It sounds like the transmission is trying to put you into "passing gear" essentially skipping the normal shift parameters and allowing you more acceleration for getting on the freeway, running from the cops, etc etc.
If you aren't a car person, transmission jobs can be very overwhelming. Good luck =)
Nate
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 574
