跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
water damage no sound
Hi, i dropped my S3 i9300 in water, i opened it and let it dry for a day post that i cleaned all the connections and put it back together,, made certain all is connected nicely.
So the phone is working fine the touch is good, camera is good, i can send and receive sms, chat i can brows net,, etc
The problem is..
there is no audio on the mobile, i cannot listen to any music, no ringer, no sound, only vibration ..
i cannot make or receive call, the call goes through technically, no no audio,, so cant listen on talk..
Please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
6条评论
did you ever get an answer to this? i have the same problem
完成的
Me too! Someone HELP!!!
完成的
Same here man only with my samsjng s4
T
完成的
My Samsung 1612 dropped in water and it's sound system does not work.
完成的
My LG k 500 n dropped in water yesterday.
I'd put it in charge.
My sound system is not working.
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Hi gill,
Here are some suggestions:
1. Does the phone work on headphones/earphones?
2. Is the flight mode switched on?
3. Have you tried the app SoundAbout?
However, since your phone experienced a water damage, there could still be water on the motherboard that causes this issue. I recommend taking the phone apart (using this guide). Now lay the motherboard into isopropyl alcohol (90%) for about 10 minutes, take it out of this "bath" and let it dry for a couple of days next to a warm source (air conditioning, for example). Put everything together again and then test it again.
Steffen
这个答案有帮助吗?
得分 3
1条评论:
It's not a phone it's a tablet
完成的
添加一条评论
Same thing happened to me. I poured a little isopropyl alcohol into the bottom two holes and now everything works fine. DON'T BE AFRAID. Alcohol does not conduct electricity!
这个答案有帮助吗?
得分 0
2条评论:
Hi there, this is a little late but can you give the exact steps of what you did?
完成的
Yes...please elaborate....did you have to some how get the ipa out afterwards?
完成的
添加一条评论
添加你的答案
gill 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 95
总计 50,089
