跳转到主内容
Samsung Galaxy S III Motherboard Replacement
你所需要的
  1. Samsung Galaxy S III Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 2 中的图像 2,2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 3 中的图像 2,2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 4 中的图像 2,2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 5 中的图像 2,2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Motherboard Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement, Battery: 步骤 6 中的图像 2,2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
  8. Samsung Galaxy S III Motherboard Replacement, SIM Card: 步骤 8 中的图像 1,3 Samsung Galaxy S III Motherboard Replacement, SIM Card: 步骤 8 中的图像 2,3 Samsung Galaxy S III Motherboard Replacement, SIM Card: 步骤 8 中的图像 3,3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy S III Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy S III Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Motherboard Replacement, microSD Card: 步骤 10 中的图像 1,3 Samsung Galaxy S III Motherboard Replacement, microSD Card: 步骤 10 中的图像 2,3 Samsung Galaxy S III Motherboard Replacement, microSD Card: 步骤 10 中的图像 3,3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Motherboard Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Motherboard Replacement, Plastic Midframe: 步骤 12 中的图像 1,1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Motherboard Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 13 中的图像 2,2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Motherboard Replacement, Headphone Jack/Speaker Assembly: 步骤 14 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement, Headphone Jack/Speaker Assembly: 步骤 14 中的图像 2,2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Motherboard Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 15 中的图像 2,2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Motherboard Replacement: 步骤 16 中的图像 1,1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
  17. Samsung Galaxy S III Motherboard Replacement, Motherboard Assembly: 步骤 17 中的图像 1,1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  18. Samsung Galaxy S III Motherboard Replacement: 步骤 18 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 18 中的图像 2,2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  19. Samsung Galaxy S III Motherboard Replacement: 步骤 19 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 19 中的图像 2,2
    • Disconnect the display data cable from the motherboard.
  20. Samsung Galaxy S III Motherboard Replacement: 步骤 20 中的图像 1,3 Samsung Galaxy S III Motherboard Replacement: 步骤 20 中的图像 2,3 Samsung Galaxy S III Motherboard Replacement: 步骤 20 中的图像 3,3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  21. Samsung Galaxy S III Motherboard Replacement: 步骤 21 中的图像 1,1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  22. Samsung Galaxy S III Motherboard Replacement: 步骤 22 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement: 步骤 22 中的图像 2,2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
  23. Samsung Galaxy S III Motherboard Replacement, Rear-Facing Camera: 步骤 23 中的图像 1,2 Samsung Galaxy S III Motherboard Replacement, Rear-Facing Camera: 步骤 23 中的图像 2,2
    • Flip the motherboard over. We recommend setting it on a grounded work surface.
    • Use a plastic opening tool to pry the rear-facing camera connector from its socket.
  24. Samsung Galaxy S III Motherboard Replacement: 步骤 24 中的图像 1,1
    • Remove the rear-facing camera off the motherboard.
  25. Samsung Galaxy S III Motherboard Replacement, Motherboard: 步骤 25 中的图像 1,1
    • The motherboard remains.
结论
269等其他人完成本指南。
42条评论
Between step 13 and 14, there should be a step to detach the cable to the camera lens and speaker assembly and the removal of the assembly.
ewu777 - 回复
Where do i buy the original motherboard and what is the cost
Mustafa Mukhtiar - 回复
I have a motherboard of samsung galaxy s3 sgh-t999 t mobile pm me here's my email tan.jeffrey84@yahoo.com for more info
Dragneel Natzu -
Cheapest place to buy them is ebay.
Tracy Smith -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 78
总计 297,274
