跳转到主内容
加入维修社区 - 创建账户
Defective power button (not working)
I have a MacBook Pro 13" Early 2011 2.3 GHz intel Core i5.
To start the mbp I have to take back cover off and remove battery connector for a couple of seconds.
After reconnecting battery and case back on, will not start with power switch. As soon as I plug mag safe in computer boots up normally (no switch or keys are pressed).
Computer operates normally in this mode, battery charges and the power can be disconnected and battery will run computer. Power can be reconnected any time to charge battery.
Problem occurs when mac is shut down, it will not restart unless I go through process described above.
i believe it is the power button/switch, I am not sure if it is shorted or open.
I have removed the button and cant see anything obvious.
The biggest issue with this is not being able to start with the battery alone, so as a portable it is not usable.
If I keep it plugged in it will go to sleep and wake up when a key is pressed, so makes a good desktop
Any suggestions would be welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
A few times on an old mbp the power button seems to have stuck in the down position and would not function. Using one (1) drop of super glue (placed carefully so that it cannot run down the side of the button) I have attached a small vertical peg to the center of the button. After plenty of drying time I have pulled slowly, gently directly up using fingers or a small pair of pliers. The button has lifted into place. Then it has operated normally until the problem recurs. The peg can be snapped off. The rough super glue surface of the button has been no problem. I was reluctant to try this but it worked out well.
完成的
hello,
I have the same problem as you. When the macbook work if I press the power button one, the sound drops each time.
Do you have the same thing?
Cordially.
完成的
my macbook pro power button not work , so i turn on from d motherboard by touching d two tots by screw driver or any metal n turns on, now its on n my keyboad r always in capital letters cant turn off caps. n some of the alphabets letters in d keyboard r not work. tis cause me a problem. how do i fix it. do i need to replace a new keyboard.
完成的
can you please post a screenshot of dots on motherboard to be touched?
完成的
添加一条评论
9个答案
已选择的解决方案
Sounds like a liquid damaged machine... check over (look for burn marks/cooked components) and clean the logic board... If there''s burn marks and corrosion you'll probably have to replace the logic board.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 4
3条评论:
Thanks for you reply
The original problem was the machine was clogged with dust, and some of the keys weren't registering. After cleaning everything, all looked fined, except on assembly the power button didn't appear to work.
I have scheduled the machine to turn on daily and that works fine (as long as machine is plugged in).
I guess I don't want to spend on a new top case if it is a logic board.
完成的
That's a work around I've used/suggested myself. =8^)
完成的
Hi. I had a similar problem. My laptop was taken apart to test the motherboard on another machine. An hour before reassembly I dropped isopropyl alcohol 100% into it, after I had already removed the logic board. On the back of the keyboard, after I removed the motherboard. The bottle had its lid loose. Can isopropyl alcohol 100% also cause this type of damage or does it dry out quickly? Any chance of being another problem? Thanks
完成的
添加一条评论
My guess is that everyone's MacBook on this post that is having the same exact problem probably have a faulty keyboard as the power button (when faulty is stuck on engaged / pressed) is part of the keyboard assembly.
If you want to confirm this, plug a magsafe charger in, press and hold control + shift + option + (alt) keys. If you see the magsafe light go green then orange then you have a faulty keyboard (from liquid damage).
这个答案有帮助吗?
得分 1
3条评论:
can you explain how this happens if the liquid dries
完成的
cant you clean it up.
完成的
Hi! I have the same issue, water damage. My left shift key doesn't work anymore, and the power button sends multiple commands (I've checked with karabiner Event-viewer). I've tried pressing control+option+command and immediately shuts down my mac.
完成的
添加一条评论
I had similar issue. So I tested the old keyboard to be sure that it not anything that has to do with the Motherboard itself or short by reconnecting the old keyboard flex to the motherboard and its power worked. After that I reconnected the new keyboard flex properly making sure that it is well inserted in the flex port. Then it worked. In summary, check your connection to the motherboard. Thanks
这个答案有帮助吗?
得分 1
1条评论:
Often this is probably the right answer. That little connector is the weak link.
完成的
添加一条评论
I'm experiencing the exact same problem too. I've permanently removed the battery and MBP works well as a desktop unit with AC plugged in. Guessing it's not worth replacing logic board because age of unit and boards are expensive. Since the unit powers on with AC 100% of time and power button doesn't work while plugged in, I thought maybe power button is permanently open. I dismiss the water damage, because it's never had a spill on keyboard.
这个答案有帮助吗?
得分 0
1条评论:
How does a water spill short the keyboard? The water dries.
完成的
添加一条评论
Apple Genius desk removed the battery and also I disconnected the battery (over night) and both times my Mac Book Pro started, but just once. When I took the back off I did find considerable fine dust. I am wondering whether those air jet things designed for cleaning computers, etc. would clean the power button. I also had no water damage although my cat likes to cozy up to the keyboard occasionally. I also don't turn mine off anymore. Keyboard component was replace a year or so ago under warranty after apparent water damage. It is three years old and updated with the newest version of software so I would think it wouldn't be that obsolete.
这个答案有帮助吗?
得分 0
1条评论:
I'm having the same issue. Did you ever figure this out? Mine started after a HD erase and reimage.
完成的
添加一条评论
I want to say how awesome IFIXIT is. No need to register. Just start talking. Love it.
这个答案有帮助吗?
得分 0
添加一条评论
I’m having the same issue. MacBook Air, A1466. Powerbutton doesn’t work. Tried the whole package, reset SMC, loosened the battery, reset SMC. Again and again just to power it up after shutting it down.
I was already having trouble to shut the Mac down. So a lightbulb started to light-up above my head. The power switch was suspect. The power button didn’t respond, also while running MacOS.
I connected an external keyboard with an power button and voila, MacOS asked directly what to do, power down, sleep etc. So I think it’s the power button. Small chance of a defect logic board, bigger chance of a defective keyboard.
这个答案有帮助吗?
得分 0
添加一条评论
I just received a MacBook pro A1278, Power Button does not work, I plugged it in with a charger and it boots up.
这个答案有帮助吗?
得分 0
添加一条评论
Yes, the keyboard is bad. The power button clicks on the keyboard underneath the power button. Over long period of time the keyboard goes bad. Replace the keyboard and you will be back in biz. Get a screwdriver with a slight magnetic charge to it. You have to remove like 100 tiny tiny screws. The magnetic charge makes it so much easier. You remove the hard drive for this process. Don't get the magnet near the hard drive. You take your time and if you forget how something goes back together, there should be a video on Youtube.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 46
总计 36,844
