跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Optical Drive hardware eject
I have an A1261 Core2duo 17" MacBook Pro which died due to a faulty logic board a few days ago. There's a dvd stuck in the drive which I want to get out. What are my options? It's out of warranty, so I don't mind tearing it down. Is there a hardware eject for the optical drive?
I'd also like to know if you guys stock logic boards for my laptop model... its a 2.5ghz core2duo 17" mbp
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Here is the guide for opening a drive to remove a disk. You must first remove the drive for the computer. I'm still looking for that guide for your computer. Ralph
Optical Drive Disc Removal Technique, or Foreign Object Removal
The best I can fin is the 15" MBP but it should give you a good idea. Ralph
MacBook Pro 15" Core 2 Duo Model A1211
这个答案有帮助吗?
得分 3
2条评论:
The right link +
完成的
Thanks for that. I got the disk out using the credit card trick :) didn't actually think it would work, but it did :P thanks anyways
完成的
添加一条评论
添加你的答案
Nikhil Venkatesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,919
