Takes a long time before it boots up!
When powering on the CAPS Lock light flashes slowly 4 times, the fan is running high and I have to wait sometimes up to 10 minutes before it boots. Sometimes it will boot up less time than this and some of the time it can take half a day to boot but when it has booted it runs fine.
Thanks for your help.
Paul
Paul, try to set your boot up sequence to your CD drive and use a Linux Live Cd to try to boot up. Let us know if that is working faster. It does sound like you have either a hard drive issue or a OS file issue.
由 oldturkey03 完成的
Thank you for your reply,
I have tried all above and still will not boot. Is there anything else that I can do?
由 Paul 完成的
So what happened when you booted with a different OS from the optical drive? What model Compaq do you have?
由 oldturkey03 完成的
