跳转到主内容
鉴别方式: 型号 M8541 / 5 或 10 GB 硬盘 / 中央转盘为机械部件
29 个问题 查看全部
Wish to replace hard drive with CF Card
Greetings...
My very original 5GB first generation iPod is finally giving out. My wife worked for an Apple company years ago when these came out and she got it as a perk for working for Apple. Well, it has been a helluva great toy, but the hard drive is wearing out (bearing I would assume) and the battery isn't quite what it used to be. So, I want to fix it. I saw this video online and thought that might work, but not sure.
http://www.youtube.com/watch?v=43ziWVWS4...
Can you advise? If the compact flash card isn't compatible, can I get a new drive? Preferably larger than 5GB I hope..
Many thanks..
Randall
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Greetings again,
Thank you for your quick responses. After doing some more research, I have found that the upgrade to CF Card isn't going to work. The adapter is for 5g video iPod.
I also read somewhere, lost track of where now, that the firmware in the iPod won't allow the use of another hard drive? Is this true? I have also been finding it difficult to find any kind of replacement hard drive at all. Just one site that wanted $89 for a 5gb.
So, I am getting a little worried that actually upgrading this isn't going to work. If I can only replace the 5G HD with the same, I really don't think it is gonna be worth the expense. Please, if you can, offer me some encouragement!? I haven't found anything stating that someone has actually upgraded one of these.
Thanks again
Randall
完成的
So nobody has tried to replace the HDD with an 50pin 1.8'' IDE SSD?
完成的
添加一条评论
3个答案
已选择的解决方案
Here is the URL for the adapter in the video. It looks like a doable project to me. Just go slow and be gentle and you should be fine. Also including a URL for flash cards. There are many suppliers of flash cards--this is just a sample. Ralph
http://www.tarkan.info/20080115/tutorial...
http://www.memorysuppliers.com/compactfl...
这个答案有帮助吗?
得分 3
1条评论:
Those adapters will not work: they are for the ZIF/LIF interfac HD's used in the 5G and later iPods; earlier iPods use 50pin 1.8"drives.
However, SSD's with this particular interface are rather plentiful on eBay. Just search (worldwide) for "kingspec ssd 50 pin" and a number of choices should pop up at very reasonable prices.
These SSD's are 5mm thick, and will therefore work in the thinner iPods generations 1 thru 4:
5 or 10 GB 1st Generation iPods
10 GB 2nd Generation iPods
10, 15 or 20 GB 3rd Generation iPods
20 GB 4th Generation iPods
20 or 30 GB iPod Photos
I don't know if they'll fit in the fat models; there should be plenty of room inside, but there's the issue of fitting the HD mounting rubbers onto the SSD, too.
完成的
添加一条评论
There are adapters that you can get for about $5-$15 online. However, CF cards are fairly expensive. 8GB's go for $20-$50 and a 32GB (Largest Available) goes for anywhere from $85 to $300
这个答案有帮助吗?
得分 1
添加一条评论
Although I don't have any links to products for you, if you simply want to upgrade to another hard drive, use this guide. To replace the battery (which you say you need to do), use this guide.
iPod 1st Generation Battery图片
指南
iPod 1st Generation Battery Replacement
难度:
中等
15 - 40 minutes
iPod 1st Generation Hard Drive图片
指南
iPod 1st Generation Hard Drive Replacement
难度:
中等
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Randall 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 21
总计 12,937
