跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2517 个问题 查看全部
Wet iPhone restore issues-what might be damaged?
Waded into a swimming pool and forgot to remove my iPhone 5 from my pocket. The phone was dead when I saw it and having tried all possible advise to dry it, its current symptoms are:
- Loops in startup but does not turn on
- Battery doesn't charge
- Retina display appears to be okay
I have gotten it to a point where iTunes recognises it and tries to restore it. However, once the apple logo and status bar is displayed on the phone, it then starts to fade away and then it loses its USB connection from my Macbook and iTunes. iTunes then gives an error (9) saying it has effectively lost the USB connection.
Understanding that it cannot be device conflicts on the USB port of the MBP, what do you think might be damaged internally? Could it just be the battery, dock connector, or a logic board problem? Note that I have not opened the phone yet.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Congrats Vince, your the first person I know of that has ever done this, kidding, here is a teardown guide, iPhone5 拆解, once your finished with the teardown follow these instructions on taking care of the water damage, the guide is for an I3 but use the same methods to clean your 5, 修复iPhone 的进水故障, after reassembly if you have any issues get back on here and let us know, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 5图片
指南
iPhone5 拆解
难度:
中等
这个答案有帮助吗?
得分 3
3条评论:
Thanks Mitch. I will try this but if you or anyone else can provide insight into what might be damaged because of the symptoms I've described, that would be greatly appreciated. I'm really hoping its just the battery and really really hoping its not the logic board or the dock connector. Thanks again. Cheers!
完成的
Vince, follow the advice given by Mitch Rush. Once you got it properly cleaned replace the battery and re-evaluate.
完成的
What might be wrong would be corrosion causing things on the logic board to short or (jump) to each other, the longer you would let this go the worse it will get till finally the board will be so corroded it would need to be replaced, other components may need replaced also but you wont know for sure till you get your phone reassembled, good luck
完成的
添加一条评论
I drop my iPhone in a tube full of water ...
I could remove it 5min minutes later only! I was luck because where I work we have a Sauna,
I left my phone there all day ... in the beginning of the night the phone started again But....
I can not activate Wi-fi either bluetooth .... Restored it and I'm having the same problem still!
Someone have an idea how I can fix it?????
Thx
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vince 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 14,021
