Why is my iPod nano screen frozen?
I was downloading music into my iPod, and now the screen is frozen! It won't let me clear it, turn it off, nothing! Please help!
hard to say - can you see it in iTunes? can you do a restore?
Once the battery has run down it will switch itself off - give it a few days. Maybe after that connecting it to a charging source will sort all out
这个答案有帮助吗?
It's perhaps a software bug? So, I suggest you follow these instruction from Apple to reset your iPod.
Learn how to reset or restart iPod following a freeze. Tip: Check out this helpful movie too.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
If your iPod is frozen or won't turn on, the steps to reset it vary by model. You caneasily tell which iPod model you have if you're not sure.
这个答案有帮助吗?
hold down the center button and the menu button at the same time and that will reset it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,985
1条评论
What generation of ipod is it?
由 AussieMac 完成的
