跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Why is my display screen in black and white only?
I resently replaced my broken touch screen....since I put the phone back together I only get black and white images on my screen .... All buttons, apps and screen work perfectly... I just don't have any color.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
3条评论
What a wacky problem!
完成的
It happened to me too. Its on my iphone 5c. When I push home 3x I get camera. Any suggestions?
完成的
I found that screen in settings. Thank you
完成的
添加一条评论
6个答案
已选择的解决方案
Is the screen actually in black and white or could it be that its in reverse black on white contrast mode http://grab.by/Zgb
if it's the latter you can find the accessibility settings in your iPhone and turn it off.
这个答案有帮助吗?
得分 9
4条评论:
Stitchrobot - You're awesome!!
完成的
which one is the home button?
完成的
What is the home button?
完成的
Mine is doing this but I have a Google Pixel 2
完成的
添加一条评论
Correct answer in my situation… Press the home button three times in succession and it will bring a menu option that says
"voice over"
"Invert colors"
"Zoom"...
You will most likely notice that the "zoom" option is checked… UNCheck this option and your screen will go back to colors!
Yea!!
这个答案有帮助吗?
得分 6
5条评论:
Awesome! Thank you so much as this has helped me!
完成的
Other experts could not fix problem, but you sure did, and many, many thanks
完成的
Thanks a bunch
完成的
Great brother,
It worked for me....thanks dude !!
完成的
Thanks I learned something New Today
完成的
添加一条评论
tap your screen 3 times with three fingers. A menu will pop up. Touch choose filter and set to none.
这个答案有帮助吗?
得分 4
1条评论:
Omg thank you so much! Todd Ramsey ☺
完成的
添加一条评论
looks like a cable issue to me (connector) - unless it's a broken screen.
But hey, colour is overrated !
这个答案有帮助吗?
得分 3
添加一条评论
I have LG Aristo that suddenly turned black/white
I tried everything, turning it off and back on, adjust settings, searched internet for help, etc...
Nothing seemed to work
)))UNTIL(((
I pulled down the screen at the top which give notifications and at the very top has signs of features that can be turned on and off by touch.
ie: WiFi strength, Sound, Bluetooth, Location, Rotation, Sync, Flashlight, Airplane Mode, Data, Battery Saver, Color Inversion and "COMFORT VIEW".
Clicked on 'COMFORT VIEW' and (((POOF))) everything went back to color.
Felt like I was in Wizard of OZ. LOL
Hope it helps fix your issue.
Have a GREAT Day!!!
这个答案有帮助吗?
得分 1
1条评论:
This solved the problem completely!
完成的
添加一条评论
On the LG XPad 2, I pressed the Hot Key once and that put it back to color.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mytech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 49,463
