跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
iPhone 4s, turns off and then right back on by itself
Hello!
firstly, let me start by saying i've personally fixed about 1,000 devices between iphones, ipads, and ipods. I am very experienced with these devices. As with any repair shop, we mostly do screen replacements and button assemblies. However, I've run into a little issue i've never seen before and the great and mighty google has not provided much insight.
I am currently working on an iPhone 4s. Phone has never been worked on and never been wet. Still 100% factory.
It functions perfectly fine in all ways EXCEPT for when you want to power it off. Hold the sleep/wake button, slide to power off comes up. It slides and does its little spinning circle and screen goes black. Then about 1-2 seconds later it turns right back on.
It will stay powered off if I plug it directly into a wall charger though? Which has got me stumped. Dock connector shows no signs of damage. I've even cleaned it well just to be sure. Again, nothing red or water damaged inside. Tried a new battery, no change.
I've seen several forum posts online and on apples website saying if a restore doesn't fix (which doesn't fix it BTW), then take to an apple store and they will replace it. Well, no dice here. The closest apple store is about 2.5 Hours away and this phone is a customers, not mine. I'm just wondering if anybody else who deals with these devices has run into this issue and what they replaced to fix it? I hate to be defeated by a issue like this. I was thinking of replacing the proximity/power button flex. But it works PERFECTLY otherwise. So i dont think its malfunctioning to turn it back on after shutdown.
Any input would be appreciated. A million tech oriented minds are better than one.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
I got a new screen battery and charger port but myn comes to logo then gos straght off then back to logo and i dont know why any help
完成的
you can try change charging port
完成的
Why my iPhone 4s turn off it self and I can’t turn it on?? Pls l help
完成的
添加一条评论
8个答案
I see this fairly regular and most of the time for me it has been corrosion on the board, or an ios update or restore fixed it, You may want to check the board closely with a microscope with all shields removed, sometimes its real hard to find it, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
working fine new battery and this problem started middle of call?
这个答案有帮助吗?
得分 0
添加一条评论
That's most likely to be a faulty dock connector. Try a replacement first.
If that doesn't fix it try a replacement battery then power flex.
这个答案有帮助吗?
得分 0
添加一条评论
I work for a large unnamed "refrubisher/insurance" company and we see this issue all the time.
The two main culprits are;
1. Corrosion on the board (IE: Liquid Damage)
2. Bad charging port assembly.
If you don't see the first, change the second. Works 99% of the time.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
I tried a few things but changing the charging port made the trick.
这个答案有帮助吗?
得分 0
添加一条评论
Same problem here....please who can tell me an liquid or spray to clean the iphone motherboard....thanks all
这个答案有帮助吗?
得分 0
2条评论:
At the end it was the battery not correctly install
完成的
Thank you very much
完成的
添加一条评论
yes i have seen this 4 times, 1 time it was the power button flex, 3 times it was the dock connector.
just unplug it and turn on/off the phone to check
这个答案有帮助吗?
得分 0
添加一条评论
Just try holding in soft reset mode through the apple logo appearing and disappearing. Should go black. Problem fixed.
这个答案有帮助吗?
得分 0
3条评论:
the hard reset did the trick for me.. so thankful..was scared because its a new battery and a new charger also.
完成的
this solution helped me get rid of the problem successfully. thanQ Joe Taji.
完成的
I have problem with my ip 4s
After call receiving or making new call
It turned off or sometime restarts
I changed 3 batteries
Anyone have solution of it??
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 89,411
