iPhone 4s, turns off and then right back on by itself
Hello!
firstly, let me start by saying i've personally fixed about 1,000 devices between iphones, ipads, and ipods. I am very experienced with these devices. As with any repair shop, we mostly do screen replacements and button assemblies. However, I've run into a little issue i've never seen before and the great and mighty google has not provided much insight.
I am currently working on an iPhone 4s. Phone has never been worked on and never been wet. Still 100% factory.
It functions perfectly fine in all ways EXCEPT for when you want to power it off. Hold the sleep/wake button, slide to power off comes up. It slides and does its little spinning circle and screen goes black. Then about 1-2 seconds later it turns right back on.
It will stay powered off if I plug it directly into a wall charger though? Which has got me stumped. Dock connector shows no signs of damage. I've even cleaned it well just to be sure. Again, nothing red or water damaged inside. Tried a new battery, no change.
I've seen several forum posts online and on apples website saying if a restore doesn't fix (which doesn't fix it BTW), then take to an apple store and they will replace it. Well, no dice here. The closest apple store is about 2.5 Hours away and this phone is a customers, not mine. I'm just wondering if anybody else who deals with these devices has run into this issue and what they replaced to fix it? I hate to be defeated by a issue like this. I was thinking of replacing the proximity/power button flex. But it works PERFECTLY otherwise. So i dont think its malfunctioning to turn it back on after shutdown.
Any input would be appreciated. A million tech oriented minds are better than one.
Thanks!
I got a new screen battery and charger port but myn comes to logo then gos straght off then back to logo and i dont know why any help
由 Matthew fletcher 完成的
you can try change charging port
由 Hasan Ali 完成的
Why my iPhone 4s turn off it self and I can’t turn it on?? Pls l help
由 郭憬謙KokKingHim 完成的
