跳转到主内容
Why is my machine being so slow with clicking noise?
Hi
I currently have the above model. Its my girlfriends and I was hoping to find out a few issues with it.
Firstly, the model was bought in 2006 and currently has 19.12 gb of space left on the internal HD.
The machine is very very slow, even with one or two programmes open.
She has adobe CS5 on the machine at the moment but it seems like the computer cant cope, although I have a similar model with the same software and there are no problems.
As well as the speed issue there is ;
-a lot of heat emitting from the left hand side of the machine
-a clicking/whirring sound coming through the left speaker.
-dvd player is tempramental
-speakers do not work
Is the processor not fast enough to handle the programmes?
Could there be an internal problem with one of the fans causing the heat and also the slow operating time?
Im at a bit of a loss so any help in getting this (otherwise perfect) machine up to speed would be amazing.
thanks in advance
David
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
My first guess would be a failing hard drive. The search head on the hard drive going back and forth can cause clicking. You can switch hard drives to verify this.
这个答案有帮助吗?
得分 2
2条评论:
Hi Mayer.
Thanks for that. Turns out the problem was a dud left fan and a dud left I/O board. Do you happen to know if I could use the I/O board from an old macbookpro A1226 in the A1211? Thanks
完成的
2.16 - Apple part #922-7911
http://www.welovemacs.com/9227911.html
2.2 - Apple part #922-8040
http://www.welovemacs.com/9228040.html
Although they appear to look the same they are not listed as interchangeable but may well be.
完成的
添加一条评论
添加你的答案
David C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 870
