跳转到主内容
问题已关闭
Why wont my iMac take any of my Mac software?
When I try to load the operating system on my iMac it only gives me the question mark with iMac 10.3 or 10.3.7 software. But when I put in the iMac 10.5.2 or Leopard 10.5 it goes all the way to which language then the next message is this software cannot be installed on this computer. What can I do to load up my Operating System? This is Model #A1144
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Your computer had a base OS of 10.4 and a max of 10.5.8. Is the software you are trying to install the black Retail version or a grey machine specific version. I suspect the latter and there are an awful lot of sellers out there selling machine specific disk as universal. If you have the grey you need to be sure its suitable for your iMac. I don't believe your computer will run 10.3. Ralph
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
That either means your processor is not enough speed as stated in the requirements or you do not have enough ram.
The Leopard OS requires a minimum or 1gb ram and a 866mhz G3 or higher processor.
这个答案有帮助吗?
得分 2
2条评论:
10.5 only requires 512 megs of memory http://support.apple.com/kb/HT3759
完成的
It also requires a G4 867 MHz or better, not a G3
完成的
添加一条评论
Dear lre1954 ,
Your Imac model No. A1144 doesn't acquire enough RAM required for Leopard OS. As Andrew has mentioned that leopard demands minimum of 1 GB RAM . So, you must check for the specifications first.
All the best.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,018
