跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Bypass Power Button To Check Logic Board?
My friend dropped cream on my macbook pro.
The magsafe is giving the green light.
When I press the power button it does not start.
Is there any pads I can short to check if the logic board in turning on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Yes there are... You realize you can blow the logic board forcing power up if the board is not completely clean and dry? They have not moved since the answer to this Question.
If this answer was helpful please remember to mark it accepted.''
这个答案有帮助吗?
得分 2
3条评论:
I have tried those pads but no luck, I have disassembled the logicboard, I am getting a green light from the magsafe the fans are connected but it does not turn on.
There was some oxidation near the keyboard connector, I cleaned it with a brush.
How do you clean liquid damaged logic boards ?
完成的
Can you check these pictures of the logicboard and tell me which ones are the pads :
http://imageshack.us/photo/my-images/407...
http://imageshack.us/photo/my-images/822...
http://imageshack.us/photo/my-images/826...
完成的
There's a whole set of advice... soft to medium brushes, dielectric contact cleaner, 99% alcohol... let it dry well (low humidity - 72 hrs)... look for a (i) power on symbol near the contacts or it may say prbn... bridging between contact #5 & #6 on the top case ribbon connector may work.
完成的
添加一条评论
添加你的答案
mbaig 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,669
