跳转到主内容
MacBook Pro No Power at all
I just brought a used MacBook Pro and brought a magsafe adapter from apple store. plugged it in and get no power. no light, only on the magsafe. Battery will charge, just no power. Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Try resetting the PMU and PRAM and let me know if that helps. Ralph
http://support.apple.com/kb/HT1431
http://support.apple.com/kb/HT1379
这个答案有帮助吗?
得分 4
3条评论:
Neither of those worked.
完成的
It begins to look like a board problem. Is there any chance of you being able to return it and get your money back? Ralph
完成的
no but thanks i might buy a board
thanks again
完成的
添加一条评论
I can show you how to open the back and boot it from the board. Sounds like the computer has power but the keyboard had liquid spilled into it and stopped working. The easiest way to find out is remove the bottom panel and boot from the pads on the logic board with a pair of tweezers. I fix liquid spilled mac's everyday. If you can send me some more info on your computer I can send you step by step photos.
Update
sorry its a bit blurry, I need a real digital camera! ANyways, these are the power pads on a 17-inch. The reason I asked you for logic board serial was so I could determine for you (and send you an image) of the correct pads. Apple in the service manual says "short the two pads together" and the easiest way is with a pair of tweezers.
这个答案有帮助吗?
得分 0
3条评论:
great answer, just watch the inflammatory comments when you answer. Thank Scott Dingle for editing
完成的
I'd be really interested in a made guide by you Josh about booting from the pads on the logic board with a pair of tweezers. What are you going to do with your old logicboard ?
完成的
oh so on all logicboards it will read pwr btn?
完成的
添加一条评论
@josh Arron's hi there. I had some water damage as well on my MacBook Pro 2011 early. Won't start. No corrosion, Can I jump it. Just a dim green light on power supply. Where are the jump pads on the logic board for this model. Any help would be greatly appreciated. I have all my work on this computer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pcwcomputer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 23
总计 8,379
