跳转到主内容
Completely reset from factory settings
PC USER GIVEN 1ST APPLE PRODUCT: LOST NEEDS HELP!!
I was given an Apple Ibook G4 model number A1134 as a gift recently although I have a little problem. Okay make that more like a medium sized, problem maybe even large. Issue is I dont have the password to the former owners user account.
Apple Ibook G4
Model Number: A1134
Operating system: Mac OS X
Is there a way to reset the laptop itself from factory settings?
Or bypass the password login?
Or anything at all i can do or was this gift pointless?
SOMEONE HELP A PC USER OUT!!! IVE NEVER HAD A MAC BEFORE, IM LOST!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
6条评论
Power on your iBook and press the "Command" and "S" keys at the same time as the computer boots. Cease holding the two buttons when you see a black computer screen appear with white text. Type "-uw/" and press "Enter."
完成的
Its saying no such file or directory
完成的
what do i do nex
完成的
The command needs a slight tweak- it is “uw /“, with a space. My Book was doing the same thing until I added the space.
完成的
@mattues password reset
完成的
显示更多的1条评论
添加一条评论
14个答案
已选择的解决方案
Here's the specs on your machine: http://everymac.com/systems/apple/ibook/...
It originally came with system X 10.4.2 (8D37)
It will take up to system 10.5.8. You may be able to get 10.4 direct from Apple for $16. Give them a call with your serial number and ask. This being to costly, try ebay. When you boot from the CD, you can go to the second screen pull down menu to Utilities > Change password, and just get rid of the old password.
这个答案有帮助吗?
得分 8
3条评论:
just google "How to restart mac with terminal"
完成的
please i need software for bootable pen drive
for another pc new install for may be acer
完成的
david putting a question about fixing an acer onto a Q&A about an Macintosh iBook is not a good idea. Start a new question and give us specifics about what you are trying to do.
完成的
添加一条评论
The gift giver should help you with the password. There are ways around the old FIRMWARE pass word if the original owner can't remember it.
If this answer was helpful please remember to mark it accepted.''
这个答案有帮助吗?
得分 6
1条评论:
Worthless.
完成的
添加一条评论
after restarting press the command+s button until a black screen with white words comes up
then type:
mount -uw /
rm /var/db/ .applesetupdone
shutdown -h now
Worked great for me, hope this helps :D
这个答案有帮助吗?
得分 5
6条评论:
tried again "no such file or diectory£
完成的
why wont it work ???
完成的
The file should be .AppleSetupDone (it is case sensitive)
Also, all this does is make it so when you power up it will go through the system setup again. All existing users are still there; all apps are still there. The only thing you are doing is renaming the computer and creating a new user.
完成的
It keeps saying password. . I can't type anything. Please help
完成的
the reason it dont work its becuz is not command+s, its option+command+f+o, and then the other steps,itl work perfect.
完成的
显示更多的1条评论
添加一条评论
This will allow you to gain access to your macbook
Step 1 of 6
Step 2 of 6
Type "-uw/" and press "Enter." This will allow you to make changes to the hard drive.
Step 3 of 6
Type "Systemstarter" and press "Enter" to run "NetInfo" (this allows you to make changes to the user accounts on your iBook). A vast amount of messages will begin appearing on your screen. When you see the message "System started" appear, hit "Enter" to display a command prompt.
Step 4 of 6
Type "niutil -list . /users" and press "Enter." A list of the user accounts on your iBook will now appear.
Step 5 of 6
Find the name of the account you are wanting to use (most likely the administrator account) and type "passwd user --" (replace "user" with the name of the account you will be using). The command prompt will tell you twice that you are changing the password for the account you chose to change; therefore, enter the name of the account twice (ensure you are typing the name of the account correctly and the "Caps Lock" is off as you will not see what you are typing).
Step 6 of 6
Type "reboot" and press "Enter" to restart your iBook. The account you want to unlock will now be completely unlocked, allowing you to freely log into the account without any trouble whatsoever.
这个答案有帮助吗?
得分 3
6条评论:
Not working
完成的
I entered /sbin/fsck -fy and then systemstarter, screen says "could not create IPC bootstrap port. Then entered niutil -list . /users and nothing happens. Any suggestions?
Steve
完成的
Just had an epiphany and the information all came to me! Thanks God
完成的
tried this many times message keeps repeating "No such file or directory" what next please?
完成的
If you are still around, sdreamer9 - PLEASE tell us what the epiphany was. I am struggling with these same problems and don't have a CLUE what to do. Thanks.
完成的
显示更多的1条评论
添加一条评论
''Oh how wrong you are, !@#$ and I wish you were correct. I just followed every thing you layed out and i rebooted back to the same Darwin from !@#$ screen.
Why is what I'm writting have the added swearing ( !&%?)
这个答案有帮助吗?
得分 1
添加一条评论
My keyboard is broken and I use the on screen keyboard is there a way to do this without typing on using the on screen keyboard?
这个答案有帮助吗?
得分 1
添加一条评论
Does anyone know how to enable cookies on an iBook g4?
Thanks
这个答案有帮助吗?
得分 1
添加一条评论
no black screen appeared even i hold it..its loading to login windows again and again
这个答案有帮助吗?
得分 1
1条评论:
.....It's loading Windows.....?!
完成的
添加一条评论
Is there a way to change the serial number of a mac when they replace the logic bd and now it has a new serial number?
这个答案有帮助吗?
得分 0
添加一条评论
After i updated the latest version of itunes on ibook64 the screen turn black and i cant open it what should i do.
这个答案有帮助吗?
得分 0
添加一条评论
is it
uw/
or
-uw/
? neither works anyway, after i found out what “command key” was…. is there a way to completely clean hard drive to be like a new computer? i have all the discs.
这个答案有帮助吗?
得分 0
添加一条评论
actully im with rachel….DOES ANYONE HAVE A LEGIT AND SOLID WAY TO RESTORE iBOOK g4 TO FACTORY….I have password i just dont know how because i dont mess with Apple for this reason right here
这个答案有帮助吗?
得分 0
1条评论:
Please read my old answer above. i'd take it to 10.5.8 using a retail install disk available on eBay.
完成的
添加一条评论
i need help because
mount -uw / worked but
rm /var/db/ .AppleSetupDone didnt this time
somebody help me fix that because i want to factory reset
这个答案有帮助吗?
得分 0
添加一条评论
hi i have bought second laptop ibook g4 and same problem he have name and password i click command and s but no screen black coming what i do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rachel Ross 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 55
总计 100,706
